NickB
#1 Posted : Thursday, April 30, 2009 2:37:44 PM(UTC)
NickB
The extrude tool set is incredibly powerful, and I find that I use the CutOut Solid (extrude a hole) tool all the time for modifying solids. However, more and more I am missing the ability to use the CutOut Solid tool, to revolve a cut, cut along a path, or do a two rail cut with a profile. Ideally almost all of the extrude tools could be used to both create a solid - the default mode, as well as create a cut. How would you do this ? Either add a bunch of options to the CutOut tool (lots of new icons for Jol to design), use the option key or a check box next to each of the extrude tool parameters to make the tool work in either the positive (solid) or negative (cut) mode.
An argument against this would be that you can always create a solid, and then subtract it, but if you use that argument, why even have the CutOut Solid tool ?
Shark FX 9 build 1143
OS X 9.5
matter.cc
#2 Posted : Thursday, April 30, 2009 4:35:17 PM(UTC)
Nick
I agree that extrude and sweep profiles with an add or subtract material options would be a great addition to the extrude tools.
Gary
#3 Posted : Thursday, April 30, 2009 7:50:06 PM(UTC)
Gary
Long ago there used to be a lip tool that was a sweep add or subtract from solid. I found it very useful and then it disappeared.
Tim, why did we loose this tool & any chance of bringing it back?
Gary
#4 Posted : Thursday, April 30, 2009 8:42:02 PM(UTC)
Gary
It was not very reliable so we pulled it out. We have created a new lip, groove, rib and flange tool in V6. The lip and groove are very similar to Solidworks where its all parametric driven. I'll put up a early preview of it when I get a chance.
#5 Posted : Thursday, April 30, 2009 8:43:32 PM(UTC)
>>An argument against this would be that you can always create a solid, and >>then subtract it, but if you use that argument, why even have the CutOut >>Solid tool
If we can combine the operations (like the cutout tool) it makes for a smaller history tree & file. I also agree it would be good to have, just need to find a way to add to the UI.
NickB
#6 Posted : Saturday, May 2, 2009 12:31:06 PM(UTC)
NickB
Tim,
Thanks for looking into this. Its this kind of direct access to to the developer / development group that makes Shark such a great tool.
As far as implementation goes I think the simplest thing would be to have a dropdown in the tool bar to make each tool work either positively or negatively. When the tool is used negatively you could revert to the CutOut Solid icon for the part history, but name the feature Cutout-Sweep, or Cutout-Lathe etc so that it is clear what is going on, while removing the need to develop a whole new bunch of icons.
OS X 9.5
matter.cc
NickB
#7 Posted : Monday, February 21, 2011 11:15:45 AM(UTC)
NickB
Tim,
Any update on this ?
Being able to do a negative one or two rail extrude and sweep would still be incredibly useful.
OS X 9.5
matter.cc
