Ryan Anderson
#1 Posted : Monday, January 3, 2011 9:04:40 AM(UTC)
Ryan Anderson
I have 2 questions :
Is there a way to have Viacad default to always copy parts with history ?
I would like to be able to copy whole assemblies with history.
Is it possible to copy an assembly with history and paste it into a new model ?
I know you can copy individual solids within the current model, but I haven't been able to move them over.
Ryan
#2 Posted : Monday, January 3, 2011 1:08:43 PM(UTC)
Hi Ryan
Try using file export (ViaCAD Shark format) but have the parts selected and check the selected only box. then use file import.
You can also try the 2 tools in rt click menu. Rt click over a part and try duplicate part with history or duplicate part as instance
Ryan Anderson
#3 Posted : Tuesday, January 4, 2011 9:24:55 AM(UTC)
Ryan Anderson
Thanks Jason,
I will try the import/export method. The right click will only let you copy 1 part at a time, and only within the original model.
Ryan
