view rotate shortcuts (#5168)
v9 build 1109 Windows 8.1 All shortcuts appear to work. Except for view- rotate. Strangely rotate forward key makes the page scroll down instead. None of the other rotate directions do anything, however the same keys DO work when assigned to other actions. On older Viacads on vista I have had this working in the past.
>>Except for view- rotate. Strangely rotate forward key makes the page scroll >>down instead. Will check. FYI, you can also use by default Shift : Arrows (up,down,left,right) to rotate the view. Tim
AH! thanks for that tip. It works .
