unique
#1 Posted : Friday, February 27, 2009 5:36:00 PM(UTC)
unique
I would like to see snaps such as centre in the snaps box and so the option to turn them off is there. When the snaps box is open I would like to be able to RMB click over say the Midpoint tickbox and only that be left available, instead of doing so many check/unchecks?
Take a look at the example avi, it shows a 2d profile being centred using tracking & combo snaps such as Between. I may be using the current snaps incorrectly so I would like for someone to explain or showme a video of how to centre the part attached.
[URL="http://www.4shared.com/file/89879761/10ee4c71/Centre.html"]http://www.4shared.com/file/89879761/10ee4c71/Centre.html[/URL]
TIA
#2 Posted : Friday, February 27, 2009 9:07:53 PM(UTC)
TIA
HI, Paul
Here is my 2 cents... how I would do it. Only need vertex snap to center object. ;)
center2dobjectji.zip (659kb) downloaded 4 time(s).
howtocentreji.vc3 (22kb) downloaded 4 time(s).
unique
#3 Posted : Saturday, February 28, 2009 6:26:23 AM(UTC)
unique
HI, Paul
Thank You Jason;)
I was trying to illustrate using snaps and how "between" snaps can be used...your method is also doo--able in Rhino but using the centre snap from a bbox (planar curve) and moving to 0,0. I think there should be a centre snap for smart polygons in VC....currently it shows endpoint snap:confused: for the centre, anyway - See link for avi below if you are interested
Actually I had tried this method a while ago when I wanted to do something similar....but the results were unpredictable.
A closer look reveals there is a bug with BBox in that it doesn't seem to extract the data from the nurbs object...instead it uses graphical feedback. That is to say when you change the resolution of the curves the bbox size goes with it, hence why I could never get the results I needed.
Tim- Whilst fixing this can you also add a mechanism for planar curves when finding its bbox, If the objects are contained in a plane parallel to a coordinate system plane, the bounding box should be a rectangular polyline otherwise a polsurface/solid box is created ??? Please!
Link to centre using bbox & centre snap [URL="http://www.4shared.com/file/89966494/4b05f02b/centre-ph.html"]http://www.4shared.com/file/89966494/4b05f02b/centre-ph.html[/URL]
unique
#4 Posted : Saturday, March 7, 2009 6:28:54 AM(UTC)
unique
Anyone else seeing this :confused:?
unique
#5 Posted : Sunday, March 8, 2009 3:40:08 PM(UTC)
unique
I would like to see centre snap on smart "closed" polygons. There is no reason it shouldn't work for basic rectangles rather than using tracking (Area centroid would do it) ?. Rhino goes one step further and can also find centre snap of non planar polygons using averages of vertex locations:cool::cool:
