unique
#1 Posted : Tuesday, March 3, 2009 7:12:09 PM(UTC)
unique
Tim/Ryan,
I wonder if this makes sense to you or maybe there is already a method im not aware of...Take an angled line drawn in the front view or anywhere in 3d space, I want to sketch geometry and create solids square to that vector. As I see it the only way to go about this is to create WPL to object & then by 3pts aligning to the coordinate system
I would like the 'WPL 3pts' to utilize the option key or by some other means...when hovering over start draws a Perp construction so that it can be picked for Z axis. I say Z and not Y because it gives the use the choice of modeling +-...or introduce a Flip Z in WPL options:p
unique attached the following image(s):
