Hi Jason,
It gets stranger.
I was looking again at what jol put forward about placing a position at each intersection, but instead of making the variable curve around the corner rads the same, I made them different, but with strange results,.. see attached image.
- Steve
(23kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
jdi000 wrote: Hi, Paul I tried var. fillet with the Automatic chain select off with your values and it did not error out but only one edge filleted but what was interesting is if you look at the fillet in object info its shows a variable fillet with all 4 point but it do not fillet the other edges. I would think that this fillet should work and there must be something that keeps generating the fillet too big error when you you use auto chain or with this one not filleting all selected edges. It would be nice to figure out what is going on. Jason
Hi Jason,
Thanks for taking a look. I see what you mean on your model...very strange.
It does surprise me that nobody has commented on this before :confused:
