PRP
#1 Posted : Tuesday, October 19, 2010 9:53:55 AM(UTC)
PRP
Is there a way to un-blend an edge? For example, after getting close to a final model, all edges blended (generally 'constant blends, radial') if you want to make major changes and have to rebuild a region, it would be helpful to be able to undo a few blended edges.
The alternative I see is to go back to an earlier model version (or backup) and start over some ways back in the design.
Anyone have tricks to solve this?
dexter
#2 Posted : Tuesday, October 19, 2010 7:58:06 PM(UTC)
dexter
Are the blends still available in the feature tree? You can parametrically alter from there.
I know that can be problematic, especially if you use the blends in features later in the modeling process.
zumer
#3 Posted : Tuesday, October 19, 2010 10:09:43 PM(UTC)
zumer
If the history tree doesn't allow it, or if a solid is imported from externally, the criteria is generally that defeaturing can be done relatively simply when the feature is built on primitive faces: planar, cylindrical, spherical or conic. Otherwise, you generally have to rebuild the faces involved.
la mouche
#4 Posted : Wednesday, October 20, 2010 2:07:04 AM(UTC)
la mouche
yes we can do :eek:
http://screencast.com/t/SglXZJjS
Antoine
PRP
#5 Posted : Thursday, October 21, 2010 3:33:53 PM(UTC)
PRP
Wow,
Thanks much. Guess I'll go back and read the manual again...
Jean-Francois Jacques
#6 Posted : Friday, October 22, 2010 10:07:39 AM(UTC)
Canada
Was thanked: 30 time(s) in 22 post(s)
We learn every day!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
