Suggestions
Can we get a plugin interface (#3752)
I just started using VIA CAD Pro V7 and I'm very impressed. My primary use is to provide models to a CAM package. I'm currently playing with a CAM package I wrote for my own purposes. The vast majority of the code is model import/selection so I'm interested in potentially embedding it in a CAD package. Obviously that requires some sort of add-on interface. I would assume some thing like this is either very easy or extremely hard depending on the internals. Alternatively a description of the via cad on disc format would be nice. The problem with going through intermediate formats like STL is you lose a lot of information about the model.
Hi ERP,
I'm brand new to ViaCaD (so take this for what it's worth) but I believe it's built on the ACIS engine by Spatial - and can export SAT format models. The ACIS engine and SAT file format specification are discussed here:
http://en.wikipedia.org/wiki/ACIS#File_format That link also contains a reference to a SAT file format guide in PDF format, which is here:
http://paulbourke.net/dataformats/sat/sat.pdf I'm not sure whether this will be what you need but I suspect it will get you further than a raw STL model for the CAM purposes you mentioned.
Hope this helps? Others with more experience may wish to chime in ;)
-- Dave
I should also mention that I would vote +1 for an embedded Ruby interpreter within the CAD tool - similar to the lines offered by Sketchup. I program in Ruby regularly and I would say the ability to interact dynamically with the CAD model using Ruby code on a console "command line" (as well as adding additional logic in the form of Ruby modules) could be quite powerful. It could also open up an eco-system of 3rd party community add-ons etc! -- Dave
Suggestions
