RichjBrown
#1 Posted : Monday, January 16, 2012 11:17:08 AM(UTC)
RichjBrown
I am having trouble with the export functionality.
When i have a drawing to share / export, i click to export to DWG and when i open the file in a DWG viewer, the walls are missing. It shows the measurements but no walls...?
Also, when i save to jpeg or print to pdf, a document is saved, but it is a blank document....
What am i doing wrong?
#2 Posted : Monday, January 16, 2012 3:26:04 PM(UTC)
Hi Rich
Can you zip up and private email me your file to [email protected].
RichjBrown
#3 Posted : Monday, January 16, 2012 4:03:34 PM(UTC)
RichjBrown
Hi Tim
How do i do that, I've only just downloaded the software, and I'm not CAD trained
Richard
#4 Posted : Monday, January 16, 2012 4:20:48 PM(UTC)
Hello Richard
Find the viacad file on your disk and right click over the name/icon and select the "Compress" option. Then attach it to an email and send to me.
Thanks!
RichjBrown
#5 Posted : Tuesday, January 17, 2012 1:21:31 AM(UTC)
RichjBrown
Hi Tim
Here is a drawing i have created this morning.
I have managed to create the doors etc, which i was having problems with.
I need to export it as a DWG and a pdf if possible but I'm struggling to do it
Cheers
Richard
Aldehey Theatre 2.vc3.zip (15kb) downloaded 5 time(s).
#6 Posted : Tuesday, January 17, 2012 2:38:59 PM(UTC)
To export the PDF
--read file into viacad
--select File:Page Layout
--select Fit to Area
I think the problem was the drawing was outside the printable area. The above should fix that.
>>as a DWG
Repeats here, checking into. For a work around until I get a fix out
---save your file as the next step changes the object type
--explode your walls into lines
---- (select Mask :Walls, this will select just walls)
--Edit:Change Object Type ->Lines
#7 Posted : Tuesday, January 17, 2012 3:46:54 PM(UTC)
>>export it as a DWG
Fixed in build 1001. Thanks for the sample file and heads up!
