Hi everyone, How do I get rid the greyed out tab for material in my BOM & Attributes. I do select my part before & open the Properties table to change the material. But when I do the BOM Table it does not copy that information onto it. Any suggestions would greatly be appreciated.
Hello Roger. 1.) in 3D-Mode (NOT Model-to-Sheet) select Part of interest. Select "Verify -> Properties" and assign Material from List. Change to Model-to-Sheet Mode and Update BOM to display Material 2.) refer to Manual Page 123 and following 3.) have you watched this video [URL="http://blog.punchcad.com/index.php/category/tips"]Tip: Adding and Removing BOM Attributes[/URL] (scroll down a little bit) ? 4.) Maybe [URL="http://forum.punchcad.com/showthread.php?t=4069"]these videos[/URL] will help you also ... Roland :)
Thanks Roland, I have been successful on a few try but not on all. I guess I do not follow the proper sequences & that tends to screw things up. BTW, I have no idea what manual you are talking about, page 123 talks about viewports on mine
Uh oh .... I was referring to the user Manual for Viacad V8 (I use the Build 1003 Trial) where you find under Capter 15 "Verify" some explanations for BOM. Roland :)
