Roger Barrette
#1 Posted : Thursday, January 19, 2012 7:06:54 AM(UTC)
Roger Barrette
Hi everyone;
Just starting using Shark FX making a 3D model of a part & wondering what step should be taken to save it as a DXF file
ie; Do dimension layers need to be off, do boxes need to be check
or do I need to draw it first in 2D then save it to a DXF.
The save DXF is for a CNC Router with the Toolpath software
Thank you in advance for any suggestion.
Roger
#2 Posted : Thursday, January 19, 2012 8:34:35 AM(UTC)
Hi Roger
You can use the draw view to generate a 2d profile.
Create new draw view xy plane copy geometry and paste into view
draw View settings pick view you want (top)
pick scale 1:1,
pick edges --> precise curves
after everything is set pick flatten draw view
clean up the geometry may be multiples of same geometry on top of each other
select geometry export dxf/dwg with selected only checked
Roger Barrette
#3 Posted : Thursday, January 19, 2012 3:44:09 PM(UTC)
Roger Barrette
Thanks Jason,
Seemed to have worked, will test it tomorrow on the CNC Router
Roger
Roger Barrette
#4 Posted : Friday, January 20, 2012 8:04:54 AM(UTC)
Roger Barrette
Thanks again, CNC router cut the profile with no problem
#5 Posted : Friday, January 20, 2012 8:30:22 PM(UTC)
Rodger
You are welcome.
