romu
#1 Posted : Monday, December 14, 2009 4:38:42 AM(UTC)
romu
Hi all,
Here are a little capture of a project I'm working on and a little VCP files.
If would like to know how I can bend the edges in the red circle on the capture? All examples I found about bending edges were about convex bending, but in my example, I need to blend concave edges.
I put the VCP here because I'm not sure I did well to reach my goal, so feel free to change the design to be able to have a smooth transition betwenn parts.
Thanks.
bend-edges.vcp (34kb) downloaded 5 time(s).
romu attached the following image(s):
#2 Posted : Monday, December 14, 2009 10:46:24 AM(UTC)
Originally Posted by: romu Go to Quoted Post
Hi all,
Thanks.
Hi Romu
What are you looking for blended edges?
romu
#3 Posted : Tuesday, December 15, 2009 6:25:08 AM(UTC)
romu
Something like this Jason, but your attempt shows me a problem in my design. I guess you added a new solid for that, did you?
I thought VC could bend concave edges as well as convex.
la mouche
#4 Posted : Tuesday, December 15, 2009 7:44:56 AM(UTC)
la mouche
hello
you need 2 faces minumum
Antoine
romu
#5 Posted : Tuesday, December 15, 2009 7:52:50 AM(UTC)
romu
Salut Antoine,
could you please describe your point a bit more?
What do you mean by "2 faces minimum"? Because in my example, I have 2 faces I want to bend together.
Thanks.
la mouche
#6 Posted : Tuesday, December 15, 2009 8:12:09 AM(UTC)
la mouche
hello my engliche... is very bad...
bud my mouse is soooooo fast
http://screencast.com/t/YTBjMjFiYzgt
Antoine
romu
#7 Posted : Tuesday, December 15, 2009 8:43:57 AM(UTC)
romu
Je vois a ;)
I'll try as soon as I can, but same as Jason, this shows me a problem in my design, so I must fix this first.
Thanks Antoine.
