Hi Paul,
unique wrote:The smooth blend in the file attached is how it should look ?
Which attached file? (edit: you added the file as I was posting: I will look later)
Those I attached to the first post are showing the "Join" which should be giving correct curvature.
The "Smooth fill curve",.. I am not yet completely sure what it is doing,.. it looks like some extension to the original lines to an interception point, then a blend is made from the new end points,.. which is not what is expected/wanted.
I have attached 2 pics showing 2 curves (both on different planes,.. but the planes are at 90)
Pic "Rhino" shows a blend in Rhino, which then does give me a number of options (G1/G2 etc) and results expected
Pic "Shark" is the result of a "Smooth fill curve" with no additional option given, and not expected/wanted
I did attempt a "Join" between the curves in Shark,, but there was no good curvature.
(61kb) downloaded 5 time(s).
(33kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
