Maybe I should stay away from splines altogether!
While 'playing' with the splines I was using as rails, when I try to select a control point I am asked to choose between the solid and a B-spline. I thought I had drawn interpolate splines! ie, I used the Interploate Spline tool to draw them!
Perhaps I should ask, what differentiates Interpolate, Control Point and Bezier splines as drawing entities?
Secondly, a line has magically appeared which has become part of my solid, and defines a new shape of the solid. See pics 4,5. It looks not unlike one of Steve's trimmed ellipses, and the solid has taken up the shape indicated by the new line. It highlights when I select the solid, and the whole solid highlights when I select the line. The original spline is still there, but is simply ignored by the solid.
I'm really getting confused now!:(
Steve, thanks for the hint about the white lines. No wonder I was having a hard time seeing them!!:rolleyes: I was successful in creating the solid from your geometry, see thumbnail below. It went cleanly following the normal steps, and looks correct, so, back to an early post, it seems to be ok on a mac.:)
Regards, Ian.
2rail-2.vc3
(163kb) downloaded 5 time(s).ianjkirby attached the following image(s):
(24kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
