2D Drafting
ISO dimensioning; problem with bottom view (#2092)
I'm using ISO dimensioning, and I'm having difficulty dimensioning the bottom view (either the view off of the side or that off of the end). I want to use the same origin as the model for all view dimensioning but dimension text and leader are incorrecty created in either the x or the y dimensions, dependent upon which of the bottom views I am using. It looks like a dimensioning limitation that needs to be addressed, but if there is a workaround (flattening the view possibly) I will try that. thanks tom
I decided that the easiest solution was to create a new copy of the model, and orient the bottom of that model as the top view. Works fine. tom
2D Drafting
