I seem to recall once having the choice to retain the cutoff from a trim solid operation, am I imagining that? I'm trying to divide a solid into two parts with a line.
I don't think you can retain the cutoff from the trim command. Use the split command with a plane as your line.
Thanks, I know I can use a surface to split a solid but I could swear we used to have the ability to split a solid in two and retain both haves with a simple line. Creating a surface simply to split a solid seems like a lot of extra work for a simple procedure, especially since a line works fine to trim already. Just need to option to keep the cutoff.
Actually, the time it takes you to put a plane versus drawing a line is much quicker in my eyes. I hope you are not making a surface per se. Just set the plane in the x, y, or z and use the plane to split the solid.
That's a good tip, thanks. What I need though is to be able to split a solid with a profile that is not planar. I've started duplicating the solid and the curve to split it with and running the operation once on one half and once again on the other. I honestly could swear there was a function to keep the trimmed part at one time.
The trim might have changed. I am not aware of it. You might have to copy paste the side you trimmed and then flip the side in the explorer on the same part so you'll have both sizes, or duplicate the part while flipping on the other copy at least in the duplicate you'll keep associativity.
