TeraVolt
#1 Posted : Saturday, October 8, 2011 3:50:10 PM(UTC)
TeraVolt
Hello,
when I use the "clip plane" view the "cutting area" of the solids always have the same plane gray and not the color of the solids.
I think a colored cutting area will be much more clearly, especially when you have few assembled parts:
UserPostedImage
Is there an option in the program to switch the "cut" color from gray to the same color as the solid has?
Thank you,
Harald
#2 Posted : Sunday, October 9, 2011 12:25:23 AM(UTC)
Harald
I agree with Teravolt !
JL
#3 Posted : Sunday, October 9, 2011 1:52:13 AM(UTC)
indeed !
... or, to an alternate colour like red in order to highlight the cut plane ?
TeraVolt
#4 Posted : Sunday, April 8, 2012 6:05:04 AM(UTC)
TeraVolt
Hello,
have found out, that the color of the cutted area is not always grey, as I think first.
The cutted area shows the color oft the infinite plane, used to clip. :eek:
Be hopeful, that this bug is eliminated in the next building of ViaCad Pro,[COLOR="red"] Tim please![/COLOR]
I often have to create parts, where they stick each into another and the clip plane function would be very very helpful if it works as it should.
Thank you,
Harald
#5 Posted : Sunday, April 8, 2012 10:45:20 AM(UTC)
I keep plugged to Teravolt!
