Tips and Tutorials
Super fine resolution not super fine enough (#4371)
Of course, decreasing line weight, it looks worse.
Originally Posted by: jdi000 >>>>>>I'm trying to export decent quality dwg files, but I just can't get the resolution high enough as all my curves seem to be broken down into lines not curves, and the resulting output isn't very nice. If you are using model to sheet in ViaCAD all curves and circles are polylines not precise lines. Only Shark has precise lines in model to sheet. Regards Jason
So in order to get good results I must use Shark? Even if I export to another higher quality CAD application using a defacto standard file system? Great. :(
That would hardly make say ViaCAD Pro "Pro" would it? If you're going to design an aeroplane, make sure you don't design it using an application named as a "pro" app, otherwise it may just fall apart after taking off!? lol!
Would it not be better to allow precise curves to be exported with a dwg, but not be available if working straight out of printing from the more consumer versions of the application?
Right, next question, is this precise line control available on Shark LT? :)
Originally Posted by: ttrw So in order to get good results I must use Shark? Even if I export to another higher quality CAD application using a defacto standard file system? Great. :( That would hardly make say ViaCAD Pro "Pro" would it? If you're going to design an aeroplane, make sure you don't design it using an application named as a "pro" app, otherwise it may just fall apart after taking off!? lol! Would it not be better to allow precise curves to be exported with a dwg, but not be available if working straight out of printing from the more consumer versions of the application?
I'm not sure if I quite follow you here Tom, but if you export your dwg/dxf from ViaCAD to Shark and do a Model to Sheet there, it will be created
with precise curves
from the precise curves within the file.
Only the Model to Sheet parts in ViaCAD get chopped up in to polylines, everything else stays precise in the export, I think.
Martin.
Thanks: 33 times Was thanked: 23 time(s) in 20 post(s)
Originally Posted by: ttrw Hi Luis. I tried regen all, but it didn't help. I'll try scaling- but I'm a novice at AutoCAD Rocky. Interesting suggestions. I'll give those a pop too. I like ViaCAD too much to give up now. :)
You might change resolution on preferences option on auto cad also, in mac, auto cad 2012 /autocad/preferences/document settings
this have option to set resolutions for polylines, arc and circles as well as 3d elements.
BTW, i openend in eDrawings a DWG exported file from shark, and the resolution display is fine, at least for me, see the attached img.
[ATTACH]4432[/ATTACH]
Luis G.
(47kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Luis, I did up the display prefs on Autocad as well, but no change. (Change in what Autocad created, yes, but no change over what ViaCAD exported- unfortunately). Martin, The actual solid data is exported as high quality, but not the vector information it seems.
To be honest, Jason's right. Pay 70 for an app, you don't expect to get the "des res"! ;)
>>Only the Model to Sheet parts in ViaCAD get chopped up in to polylines, >>everything else stays precise in the export, I think. Correct. The model to sheet tool in the ViaCAD products creates polylines. We do some limited checks if the polyline is a hole and convert back to a circle. Shark licenses the CATIA V5 PHL 3D to 2D technology to create the 2D drawings. This technology creates precise curves. This technology component has some additional license fees and restrictions from Dassault that prohibit us from putting into ViaCAD. Tim
It's fair enough Tim. :) Thanks for clearing that up. But will LT give the same results as FX?
So this is the answer, sorry for confusing things, I am using shark not Viacad, so forget about my posts on this thread. Luis G.
>> will LT give the same results as FX? Shark LT uses the same PHL V5 technology as Shark FX to create M2S draw views. Tim
Originally Posted by: ttrw To be honest, Jason's right. Pay 70 for an app, you don't expect to get the "des res"! ;)
Tom
No it's not that simple and that is not what I meant. ViaCAD output is excellent.
If the geometry is drawn it outputs precise lines it's only the 3d to 2d conversion that is polylines so just draw the views u need and you will have precise output.
Never mind. Let's all have a beer eh? :) Thanks for all the help and suggestions. :)
Tips and Tutorials
