Suggestions
ability to select surface (#2582)
Originally Posted by: ZeroLengthCurve A couple of weeks ago I tried "writing" text along a convex curved surface. My efforts failed miserably.
Post an example, we can all have a play then.
- Steve
Edit:
Using VC pro I made some text cut out of a curved surface solid;-
(99kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 92 times Was thanked: 100 time(s) in 64 post(s)
Wow! Thanks! That is nice. Can i safely assume that even with the curved solid, one can remove material and the remaining lines (edges making the outlines of the letters) will be perpendicular to the surface? This seems really great. This is useful for etching the ship names and draft markings/load lines onto hull surfaces (helps the painters/bosuns paint in the right location and aids inspectors in the even the paint wears off or cheats try to fake their draft). A ship drafter i know said a few years ago he and his coworker simply could not get satisfactory results out of AutoCAD. Now that ACAD 2009 & 2010 are in place where he works, it would be very nice to find out that VCP can do this and ACAD cannot. I'll have to ask him if my memory is correct and that i'm not misquoting him. Again, thanks, Steve, for the example!
Originally Posted by: ZeroLengthCurve Can i safely assume that even with the curved solid, one can remove material and the remaining lines (edges making the outlines of the letters) will be perpendicular to the surface?
Yes.
Here is a quick example showing the perpendicular outer edges of the curved solid.
(19kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Suggestions
