Originally Posted by: posh.de ...within a virtual machine instead of natively under Windows... you're kiddin'
nope, not kidding. i wasnt comparing them, but i believe 64bit MAC in VM (on good hardware) will be better than the 32bit Windoze counterpart not in VM. i dont have MAC, so a system with a virtual layer will suffice for me to run the 64bit MAC version of ViaCAD. the hardware specs i posted should be ok for what i need, etc. if i go dual Xeon i have option up to 512GB RAM.
Edit:
initial host specs are:
asus mobo maximus VI gene
intel gen4 i7 extreme (will oc this), but maybe a gen3 hex core
windoze 8.1 pro
one of the nVidia Geforce cards, maybe gtx760 192bit
vmware workstation 9.0.3
32GB (8x4 @ 1G density) ram ddr3-1866
~500GB SSD drive (not sure which brand yet)
corsair vengeance case w/ dual fan chiller
Originally Posted by: posh.de shure, it's just setting a compiler switch and you're done :rolleyes:
i didnt say it was just a switch. but source carry-over should be high, MAC is basically Linux. its not like going from all Windoze to nix, etc.
