Is it possible at all to confine movement of an object to an axis? (#2340)
Hi, I have asked this before but never got a real answer. So please plain and simple, is it possible to grab a 3D object with the mouse and move it with the movement constrained to 1 axis? Holding down x, y or z does not work. The object can be moved on all axi with x, y or z pressed. It does not constrain te movement to that axis. thanks, Daan
Hi Daan. Can you not just use the up, down, left, right arrow keys while holding down shift? This rotates the object in increments of 5 (I believe?).
Thanks, but I am not trying to rotate the object. All I want is to be able to grab an object and move it just on any one axis. I want to be able to grab an edge and move the object along either the x, y or z-axis and that axis only. I cant seem to do this in any way and trying to position objects is driving me crazy. I postion them in either the left, right or topview but whenever I change views the object also has been displaced on some unexpected axis and is nowwhere near where I need it to be.
hmm okay. Can I ask what software you have used before that allows you to do that? You can freedrag objects using the mouse, but you can't snap (afaik) to any specific axis. VC and Shark, well, are quite different in the way they approach modelling, and it can be really painful to learn them if you have come from another system. I spend a lot of time swearing at the software!!
That's what the LogiCursor is supposed to ease, but although it interprets the axis, I haven't found a way to constrain the distance before the move, only afterwards. How it works is: Select the object and nominate the index point. Moving (the object by grabbing the index point) along the selected axis brings up the (manual move) distance in the dx, dy, or dz boxes. Tab to the dx, dy or dz dimension and overwrite the distance to that that you wanted, the object will move to the correct point.
daan, Have you tried what I previously suggested, turn on "work plane" in your snaps palette and use the move tool. This way, when you are in a projection view, top, front, side, you will be able to snap to all snap points, but movements will be limited to only the two axis you view. No 3rd axis surprises. Gary
Hi Daan Turn on the workplane snap and first select the workplane for the view you want top, right, left side and then pick the corresponding view top right left side , with the workplane snap on and the workplane set you will only be able to snap to the workplane so moving the object right/left and top/bottom in the work plane thus confining movement. Regards Jason
Hi Daan,
As mentioned in this thread and the last one you made concerning this, enable the snapping for "Work plane". That does work (certainy on windows setup).
There is mention in the bug fixes for build 834:-
Quote: 18. Locking onto an axis now locks alignment to last alignment point.
Which
may sort out this problem.
- Steve
I have enabled snapping on the work plane all this time. I just can seem to move an object any other way than through the x, y, z inputs at the top by trial and error. Using the translate also throws the object around all over the place without any logic. Somehow my object ALWAYS get moved allong more axis than I intend to. As for other software I have used a whole range of 3D modeling software, lightwave - cinema 4D - animation master - silo, and in none of these programs it's any trouble to just place an object in the place you want it to be. Just move x, y and z axis one at the time in 2 views, presto exact allignment. I bought viacad because I was looking for something a bit more cad like because I use the models I create to drive my CNC mill. BUT TO SUM IT UP: IT IS INDEED IMPOSSIBLE TO CONSTRAIN MOVEMENT OF AN OBJECT TO ANY ONE AXIS AT A TIME, RIGHT? The only question that comes to my mind is why? Why wont holding down the x, y or z key constrain the movement of the object your moving to that axis? Most people here seem to think it does, but it clearly doesnt.
HI Daan
The xyz keys are intended to constrain movement in those axis, but there were some improvements to that feature in one of the latest builds of the software build 833 or 834 that greatly improved the axis locking, email Tim and when early release comes out you can get a patch. Follow instructions below.
Originally Posted by: Tim Olson I just sent out an email with links for a ViaCAD 2D/3D V6 patch to those registered users who have requested early patches.
If you are a registered user of ViaCAD 2D/3D V6 and would like to get early patches, send me a private email with your serial number.
tim.olson@punchsoftware.com Regards
Originally Posted by: Daan Muller I have enabled snapping on the work plane all this time. Using the translate also throws the object around all over the place without any logic. Somehow my object ALWAYS get moved allong more axis than I intend to.
Hi Daan
The translate tool (dx dy dz) works in what workplane you have activated. Use show workplane to see the light blue arrows showing the workplane.
You can set the workplane by using the lowercase c key if you hover over a point on an object till one of the snap boxes displays like endpoint, vertex, midpoint then hit c key it will place the workplane at that point keep hitting the key and it will toggle the workplane position.
The problem appears to be fixed with the latest build. - Steve
Daan,
Email me your serial number and email address and I will include you on our pre-release builds for V6.
Regards,
tim.olson@punchsoftware.com Tim Olson IMSI Design/Encore
Originally Posted by: Steve.M The problem appears to be fixed with the latest build.
Forget that. There is still a problem with using the keyboard axis constrains.
- Steve
