Suds
#1 Posted : Sunday, February 27, 2011 4:49:20 PM(UTC)
Suds
OK, probably a odd-ball item......
But as a example. A Gilmore (timing belt). I'm working on a project that uses these and open ended. Would be nice to create one 'wavelength' then be able to extrude it to the length I need.
Or is my thinking wrong?
Tem
#2 Posted : Sunday, February 27, 2011 11:26:52 PM(UTC)
Tem
Maybe create the length you need>pattern>Boolean "Add"?
Or you could Boolean Subtract a pattern from a solid as well?
There could be several other approaches. But these came to mind first.
la mouche
#3 Posted : Tuesday, March 1, 2011 3:07:57 AM(UTC)
la mouche
Hello,
you can use:
1 - Tool helix.
2 - controlling dimensions.
3 - projecting the helix on the plan to get a sine wave.
4 - extrude with optional thin extrusion.
and voil :)
http://screencast.com/t/iUsgAwQE4JCi
Antoine
Jean-Francois Jacques
#4 Posted : Tuesday, March 1, 2011 11:18:08 AM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
Nice Tips...Antoine
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
