Tem
#1 Posted : Wednesday, May 27, 2009 3:02:17 PM(UTC)
Tem
What are the "CAD" rules for being able to split / trim curves, other than the obvious "they must intersect" rule? Are Groups or Blocks of curves not good to try and slice and dice? Anything else?
Thanks!
unique
#2 Posted : Friday, May 29, 2009 4:19:23 PM(UTC)
unique
Thanks!
Not really mate :( have you looked at the help any ?
VC desperately needs the ability to window select geometry in order to trim/split multiple items in one go ? It's very very painful and long winded at the minute..Tim is this on the agenda for change ?
#3 Posted : Saturday, May 30, 2009 4:24:17 PM(UTC)
>>VC desperately needs the ability to window select geometry in order to >>trim/split multiple items in one go ? It's very very painful and long winded >>at the minute..Tim is this on the agenda for change ?
Paul, no activity here. When I trim a bunch of stuff, I usually double click on the arrow tool to select all, then select the trim tool and just click the pieces to remove. Or if its a area, I will use the region trim command.
http://www.csi-concepts.com/Demo/videos/trim.mov
Is that what your looking for or something else?
