to all with your fast and helpfully replies.
I started to rebuild my ring with ViaCadPro, bending along spline ( great tool ) and mirror.
Now it workes. I do not know why.
I tried to change the resolution and the color.
I tried the file from Steve. i had no chance. So i rebuilt it in a different way ( only one booling operations ) and it works.
if you like you can see one of the results in the attachement.:)
awieneke attached the following image(s):
(8kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 221 times Was thanked: 171 time(s) in 103 post(s)
Brilliant result Andreas ! How did you make the stones ? JL
Originally Posted by: jlm Brilliant result Andreas ! How did you make the stones ? JL
Thank you,
the stones (long time ago ) and the rendering i made in cinema 4d.
next time i try to import the stones into the symbols of ViaCad and test how it is usable for me.
Hi Andreas,
Originally Posted by: awieneke I tried the file from Steve. i had no chance.
I find that strange unless there is some problem with the mac version with blending. Did you get any error popups while attempting to blend?
Could someone with a mac version please look at this, TIA
I was going to upload the model with the blends, but I keep getting an "upload failed" (maybe an unintentional limit on the vc3 files).
- Steve
Originally Posted by: Steve.M any error popups - Steve
yes, two different error popups
please see the pictures
in the begining i used ViaCad 6, also with the mac version.
what do you mean with TIA ?
(11kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: awieneke what do you mean with TIA ?
That is just
T hanks
I n
A dvance
I am seeing no problem with the blending with current beta. Maybe some update to the beta is resolving this problem?
I have been attempting to attach the model with the blends/rads, but I keep getting an upload failed, so I can only attach a pic.
(64kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Steve.M That is just T hanks I n A with the blends/rads
super, your blending looks how i want it.
Do you pick the edges in a certain order ?
TIA :)
Originally Posted by: awieneke Do you pick the edges in a certain order ?
Yes, I blended the 4 intersections first:-
(66kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Steve.M Yes, I blended the 4 intersections first:-
no way in my file, probably you are right, it could be different to the mac version.
I have been able to upload the model with the blends/rads as a compressed (zipped) sat file.
blending_p05_rads.zip
(193kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Steve.M I have been able to upload the model with the blends/rads as a compressed (zipped) sat file.
Thank you Steve,
if it is not too much work, could you send me the file which includes the history ( features tree)
TIA :-)
Originally Posted by: awieneke if it is not too much work, could you send me the file which includes the history ( features tree)
I have uploaded to uploading[dot]com
http://www.uploading.com/files/...ending_p05_rads.vc3.html
Originally Posted by: Steve.M I have uploaded[/url]
Thank you,
funny i can open your file with ViaCad 6 but if i try to open it with ViaCad Pro i get an errormessage: this file is damaged cannot read into application.
Anyway i can change the blending value in ViaCad 6
Hope the upgrade to viaCad_Pro_6 will come soon :-)
Originally Posted by: awieneke Hope the upgrade to viaCad_Pro_6 will come soon :-)
I think it will be after the release of Shark LT.
You could look at the shark LT beta, yes,.. before you mention, beta software is not something everyone wants to use, but the current beta`s are actually for testing the current releases with bug fixes. It is not a case of new commands etc being tested, just a case of reported issues being fixed.
It would certainly help yourself to use the beta, and your feedback would also be from the current version, and help with finding problems.
There is a post
http://forum.punchcad.com/showthread.php?t=1508 with links for the shark LT beta.
- Steve
Thank you Steve, for the link to shark beta, the download is running in this moment and i will try to work with. I just bought ViaCad pro ( a kind of downgrade from ViaCad 6 ) and actually i have a to learn all the features it provides. in the special the great bendigtool ( bend along path ) i love and it is very usefull for me. i become very fast familiarly with your software :) i will tell you how i like shark beta
Originally Posted by: awieneke Thank you Steve, i become very fast familiarly with your software :)
Yes Steve, your software is greeeeaaaat !! :D:D
Originally Posted by: Steve.M I find that strange unless there is some problem with the mac version with blending. Did you get any error popups while attempting to blend? Could someone with a mac version please look at this, TIA
Steve Your re-built file blends fine on the mac version. There are some small peculiarities however: If I select the entire model for blending only the top edges blend. If I blend the short edges first then select everything ViaCad hangs and has to be killed.
It is possible to get all sorts of errors if the short edges are not blended first because the blends of the other edges try to run into each other if the radius is greater than 0.1mm
Doing the blending in the order short edges, top, bottom then inner works fine.
