awieneke
#1 Posted : Wednesday, September 25, 2013 1:04:21 PM(UTC)
awieneke
Hallo,
i draw a very simple ring and want to blend the edges.
But the result is very 'funy'
Please see the pictures.
awieneke attached the following image(s):
Bildschirmfoto 2013-09-25 um 20.58.04.jpg (56kb) downloaded 5 time(s).
Bildschirmfoto 2013-09-25 um 20.58.15.jpg (63kb) downloaded 5 time(s).
Jean-Francois Jacques
#2 Posted : Wednesday, September 25, 2013 1:12:55 PM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
Go in your history, remove feature (right click), do undo. and voil it's magic!!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#3 Posted : Wednesday, September 25, 2013 1:18:55 PM(UTC)
Canada
Go in your history, remove feature (right click), do undo... and voil it's magic!!
Jean-Francois Jacques attached the following image(s):
#4 Posted : Wednesday, September 25, 2013 1:24:21 PM(UTC)
Canada
I did the previous example with Shark FX beta V9. If you don't have success, try to change the resolution via the menu bar Edit/Change resolution/ Super Fine - Precise Facets...
awieneke
#5 Posted : Thursday, September 26, 2013 3:44:17 AM(UTC)
awieneke
the 'remove and undo' workaround is not working in my ViaCad version 7. Also the change of the resolution makes no different.
blowlamp
#6 Posted : Thursday, September 26, 2013 3:54:39 AM(UTC)
blowlamp
Go to a blank part of the screen and try right-clicking the mouse and then selecting Hide All > Curves.
Martin.
awieneke
#7 Posted : Thursday, September 26, 2013 7:48:49 AM(UTC)
awieneke
Martin.
this will not change my blending.
after changing this solid in an surface part, the thing is a surface.
Bildschirmfoto 2013-09-26 um 15.46.46.jpg (66kb) downloaded 5 time(s).
Bildschirmfoto 2013-09-26 um 15.45.41.jpg (156kb) downloaded 5 time(s).
rockyroad_us
#8 Posted : Thursday, September 26, 2013 8:17:11 AM(UTC)
rockyroad_us
Not sure what is it that makes the blend funny as your original quote. Maybe elaborate more. It seems you need to hide the points or curves as someone suggested so that you only have the solid.
awieneke
#9 Posted : Thursday, September 26, 2013 8:50:06 AM(UTC)
awieneke
o.k.
i copy the ring, paste it into a new document and the blending is as funny as in the original document.
blowlamp
#10 Posted : Thursday, September 26, 2013 9:06:43 AM(UTC)
blowlamp
Oh sorry, I totally missed what the real problem was and I can't explain where that surface is coming from.
Use the Select Deep tool to pick that naughty surface and press Delete to erase it.
However, if you save your job (minus the blend) as a STEP file and then open that STEP file, I found that the blend worked OK.
Martin.
rockyroad_us
#11 Posted : Thursday, September 26, 2013 10:05:31 AM(UTC)
rockyroad_us
you need the precise facets checked in object resolution. That worked for me to get rid of the surface that fills the hole.
awieneke
#12 Posted : Thursday, September 26, 2013 10:37:05 AM(UTC)
awieneke
Martin.
Thank you,
as a step file, it works, but it loses the history, what i often use, for example, just to change the rings size.
awieneke
#13 Posted : Thursday, September 26, 2013 10:41:54 AM(UTC)
awieneke
and on the bottom side it works !
i found it and it works :-) great !
edit > change resolution > precise facets
Thank you
