heecheee
#1 Posted : Wednesday, February 26, 2014 5:57:57 PM(UTC)
heecheee
After the replacement of PC (1stgen MacPro→2009MacPro), ViaCAD Pro V9 is asks for re-activation.
Please tell me how to get activation code.:(
heecheee attached the following image(s):
ViaCAD Pro 9ScreenSnapz001.jpg (64kb) downloaded 3 time(s).
CNC_Kid
#2 Posted : Thursday, February 27, 2014 9:10:36 AM(UTC)
CNC_Kid
hah, i had same exact issue yesterday after doing memory upgrade to my laptop from 4 to 8GB. i had to ping support, didnt get a reply yet. but for fastest fix you should call their support line.
i am also planning to dupe the HD to a SSD, so i wonder if i will run into this issue again...?
update: support has to issue a special code using the request code as displayed, which means you have to leave that window parked on that screen, send support (or call) that request code, and then support will send special activation code. after entering the special code you can re-enter your original activation code.
a messy process indeed, but this is what support says......
VCpro v11-1417
Win10Pro 32GB
Xeon E3-1270-v3 3.5GHz
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
heecheee
#3 Posted : Friday, February 28, 2014 6:14:01 AM(UTC)
heecheee
Thank you for your advice.:)
I will send email to support.
CNC_Kid
#4 Posted : Friday, February 28, 2014 11:56:46 AM(UTC)
CNC_Kid
if you have not contacted them before via email then you need to call. for some odd reason they like to initiate the email communications.
although they told me the code they give to fix the issue was to clear the error, and they i would need to re-enter my original code from my purchase receipt, i did not have to re-enter my code from my receipt, the fix they gave me simply fixed the issue, now my VC starts just fine.
as for the "fingerprint" bit, dunno, i suspect its from a change of RAM. swapping over to a SSD didnt affect VC9.
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
heecheee
#5 Posted : Friday, February 28, 2014 6:19:17 PM(UTC)
heecheee
I sent email to support at http://support.encore.com/order...t/order_support_frm.aspx
There was communication from support and was settled afterwards.
He sent me activation code for "clean the registration process".
The input of my original activation code was unnecessary for me.
