victorf57
#1 Posted : Saturday, October 6, 2012 1:48:22 PM(UTC)
victorf57
OK Guy’s I hope this isn’t so simple you’ll make fun of me :)
In solidWorks a part is made and then an assembly is assembled using all of the different parts.
If we wanted to do the same thing in Viacad 2D/3D ver 8 build 1003, how would we go about it?
I’ve tried making parts and then making blocks out of them and then adding them together
But I’m not having to much luck, it seems once the part is blocked it can’t be moved. If someone has a video,
or link to an assembly made out of individual parts/components that would be great.
I’m also thinking about upgrading to ViaCad Pro8 when released. If it would make things easier.
Thank you
Victor
rockyroad_us
#2 Posted : Saturday, October 6, 2012 4:19:51 PM(UTC)
rockyroad_us
In sharkfx, there's a feature called reference manager where you link one file to another. Sort of like a canvas of your parts coming together in one file to form an assembly in another file. That's how I do it. I do it this way to keep all parts in separate files. I don't know if viacad pro 8 has this feature.
I don't use solidworks so I don't know how it does its assembly.
BPL-RFE
#3 Posted : Sunday, October 7, 2012 2:40:02 PM(UTC)
BPL-RFE
Hello Victor.
I am also using Solidworks as an employee at Work now for 10 years.
At Home i am playing around with viacad as part of my private interests.
During Installation you were asked if you would like the example files to be
installed as well.
So take a look at them ...
Open them and say "Verify" > "Object Counts ...".
There you will find several assemblies.
As far as i got with my understanding:
- in Viacad we have several parts consisting of
> 1 solid
> or several meshes
> or several curves
> or one or more surfaces
- the parts can be grouped and positioned to each other to your liking
- as long as you don't change something on the parts each part
is treated individually.
- in Solidworks we have the files
> for the parts containing the solid/surface-Data
> the file for the assembly, containing the information
> which file how often
> grouped ? single ?
> in which relative position in the assembly (location of origin and
orientation of part
- in ViaCAD we have no such thing (AFAIK)
- all is stored in one single file
- Your file is too big ? You ran out of memory ?
> Well, maybe not all of your parts needed to be shown in super fine
resolution
> Do all your files need to be solids ?
Screws, Nuts, Bolts and parts where only the outer surface is of interest
surely not ...
Maybe converting them to surfaces will make things better ...
> look at the number of facets ...
The more factes, the bigger the file will get.
Do you need to show every little blend on every part ?
> always remember the purpose of your data
- rapid prototyping would need in best case solids
- rendering ? well, mybe grouped surfaces/meshes would also
do the job ...
- technical documentation ? Well, that depends, use your brain,
that's why you have it ...
Hope nobodys laughing at me right now ...
Roland
