blowlamp
#1 Posted : Saturday, August 30, 2008 4:58:50 PM(UTC)
blowlamp
Greetings all.
Does anyone know if ViaCad can apply a surface to a Point Cloud, so I can save it as an STL file for subsequent machining?
Attached is a sample file I grabbed from the internet, which should do nicely for demonstation purposes.
Thanks, Martin.
wrench.vc3 (480kb) downloaded 5 time(s).
#2 Posted : Saturday, August 30, 2008 5:56:14 PM(UTC)
Martin
Did you try the standard export for stl from ViaCAD and try that for machining? The point cloud is usually the raw data that is converted into stl format. I think that ViaCAD pro and up can convert surfaces into points but not ViaCAD 2d/3d.
#3 Posted : Saturday, August 30, 2008 6:47:49 PM(UTC)
Martin
Try selecting a solid and going into object properties and adding u v lines as many as you want. Then select everything and edit change object type to curves. Then use the points along curve tool and you can build a point like cloud with as many points as you want from a solid.
blowlamp
#4 Posted : Sunday, August 31, 2008 1:55:57 AM(UTC)
blowlamp
Jason.
Yes, I tried that, but it just throws up an error message when I try to save the file. I need some way of applying a surface to the collection of points, so it creates a mesh before I save it.
Thanks, Martin.
#5 Posted : Sunday, August 31, 2008 9:15:16 AM(UTC)
Martin
Sorry I misread you first post you want point cloud x,y,z data to surfaces. Is this something you want to do a lot or just a couple of times? Are you digitizing your own data from a sample?
blowlamp
#6 Posted : Sunday, August 31, 2008 5:33:14 PM(UTC)
blowlamp
Hi Jason.
I've been asked to recreate some embossed plaques and I wanted to use a digitising probe on my cnc milling machine to create a point cloud image, but I need to make it into a mesh first, for use with the CAM software. It's the sort of function I wouldn't use every day, but would be a valuable addition to my arsenal.
Thanks for your help, Martin.
#7 Posted : Monday, September 1, 2008 12:53:56 AM(UTC)
You can use points as the internal 'guides' in a cover surface with guides
Have you tried this ?
Not sure - Perhaps this is only in Shark !?
Guest (11)
