Bill Cottrell
#1 Posted : Monday, July 16, 2007 4:44:05 PM(UTC)
Bill Cottrell
I am new to concepts 2D but many (many more than I care to think about) years ago used an early version of Acad. I still remember some of how Acad worked. I am using the line command and know there must be an easier way to do what I am trying. Is it possible to call out a line by angle and/or length without first drawing a line and then editing it? What is the easy way to draw a line .105 long @ 270 degrees, from that another line 3.5 long @ 0 degrees, another from that at .325 long @ 90 degrees and then to close the box. Acad you just pushed "c" for close to do this.
I know there has to be a lot easier way to do this than I have found so far. Thanks for any help.
Bill Cottrell
#2 Posted : Wednesday, July 18, 2007 8:16:11 PM(UTC)
Bill Cottrell
Duh - I guess it helps to read the manual. I figured it out (I think). It would be nice to have a normal help section rather than everything being on a .PDF file. Now if I can just figure out how to get things to rotate like I'm used to.
#3 Posted : Saturday, December 22, 2007 12:02:01 PM(UTC)
There is a 'dynamic help' which is html based. Not very well presented but you can get it by pressing the '?' on the top line of the current tool you're in - not sure if that helps.
