martinwh99
#1 Posted : Thursday, September 11, 2014 4:55:28 AM(UTC)
martinwh99
Switzerland
How do i find gabs and overlapping lines? When i do select chain it selects all. And when i do extrude it tells me i have gabs or overlapping lines. But how cant i find them. Thanks
Martin Krueger
ViaCAD ProV9, Cut2D, Cut3D
rockyroad_us
#2 Posted : Thursday, September 11, 2014 8:42:56 AM(UTC)
rockyroad_us
For overlapping lines, you would have to select all lines and check the listing in your concept explorer. I believe you can scroll/select the line in the explorer and the line will turn red by itself so you can see which one it is.
For gaps, there are two approaches. You can just project all lines to a working plane. Most likely you drew stuff without work plane enabled in snaps. The alternative is to inspect the end points or redraw it with work plane enabled.
Hope this helps.
rokoko
#3 Posted : Thursday, September 11, 2014 9:39:57 AM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
hi,
you can also find some helpful tips in tips-book (can be obtained with costs on http://www.masterviacad.com/viacadtips/viacadtips.html)
or try the connect curve tool to repair open lines
Jean-Francois Jacques
#4 Posted : Thursday, September 11, 2014 10:48:16 AM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
Hello Tim,
I want to buy your ViaCad tips book (in hard copy). Do you work or do you expect to work for a new edition included the Version 9?? In this case I will wait for this..in other case I will order the book via Amazon!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
martinwh99
#5 Posted : Friday, September 12, 2014 2:37:35 AM(UTC)
martinwh99
Switzerland
because i have hundreds of control point splines it will bi funny to find out. But i'll try
Hope this helps.
I will try this too.
Originally Posted by: rokoko Go to Quoted Post
hi,
i've tried this but it told me that i have to ungroup my object although it was'nt grouped. But thanks for the hint with the book. i'll get it today.
Martin Krueger
martinwh99
#6 Posted : Friday, September 12, 2014 6:55:50 AM(UTC)
martinwh99
Switzerland
hi,
Hi rokoko
thanks again for that link. This is really a great document. I have to work through this one first before keep on questioning. :):) thanks
Martin Krueger
