Is it possible to convert any of the built in text fonts into a object that could be extruded into a solid ? This would be extremely useful for embossing and other applications.
Originally Posted by: CobraJet390 Is it possible to convert any of the built in text fonts into a object that could be extruded into a solid ? This would be extremely useful for embossing and other applications.
The extrude tool will take a Text entity from a truetype font and extrude into a solid. If you look around 4:30 in this video you will see Text used as protrusion.
http://www.csi-concepts.com/Demo/videos/signet_ring.mp4 I'm also researching an emboss tool that would work across non planar surfaces using a new API recently added in ACIS R25.
http://doc.spatial.com/index.php/Wrapping_a_Planar_Body Regards
Thanks Tim, As always, excellent support !
Originally Posted by: Tim Olson I'm also researching an emboss tool that would work across non planar surfaces using a new API recently added in ACIS R25.
In MoI its called "flow" there are a million and one uses for this tool. Look forward to seeing it in future versions of the software.
Edited by user Thursday, October 2, 2014 3:05:29 PM(UTC)
| Reason: Quotes in the wrong place
>>In MoI its called "flow" there are a million and one uses for this tool. I'm a big fan of MoI flow. This is not as powerful but a step forward for Spatial. Tim
