hmmueller
#1 Posted : Friday, October 3, 2014 12:55:26 PM(UTC)
hmmueller
(ViaCAD 9, build 1104)
I have a layer 1 with some objects and a layer 2 that is empty.
I
  1. make layer 1 the "work layer" (with the pen symbol in the concept explorer).
  2. select all objects (Ctrl-A)
  3. copy them (Ctrl-C),
  4. and finally make layer 2 the "work layer" (with the pen symbol in the concept explorer).
Now, when I
  • press Ctrl-V, the objects are pasted into layer 1 (even though "Preserve layers" is not checked in the "Paste options"; this seems to contradict the documentation which says under "Preserve Layers": "If this option is not selected, pasted objects will use the current construction layer.")
  • do "Edit--Paste", the objects are pasted into layer 2.
I'd say this is a bug.
Harald M.
rokoko
#2 Posted : Friday, October 3, 2014 1:50:03 PM(UTC)
rokoko
hi,
i have viacad pro 9 (build 1109 english) on mac and both commands (cmd + v, edit -> paste) are working correct with layers.
you could try to get the most recent build via menu: help -> current version
Edited by user Friday, October 3, 2014 1:56:04 PM(UTC)  | Reason: Not specified
hmmueller
#3 Posted : Friday, October 3, 2014 2:33:02 PM(UTC)
hmmueller
I've downloaded and installed build 1109 on my Win7 machine - and it still does not work (i.e., Ctrl-V still pastes to the layer(s) where the copied (Ctrl-C'ed) objects live, whereas Edit->Paste copies to the construction layer.
Thx anyway.
Harald M.
#4 Posted : Friday, October 3, 2014 4:20:59 PM(UTC)
I have not been able to get this to repeat. Edit->Paste and Ctrl-V call the same paste procedure. I tested with a simple circle, maybe it's geometry related. What is the geometry you are copy/pasting?
#5 Posted : Saturday, October 4, 2014 12:41:00 AM(UTC)
I
Now, when I
Harald M.
I have exactly the same issue with Shark.
The only way to have ctrl-V working is to click in the window before (then it pastes at the clicked point)...
#6 Posted : Saturday, October 4, 2014 1:08:32 AM(UTC)
I
Now, when I
Harald M.
I can repeat with Shark, unfortunately.
The only way to get cmd-v working is to click in the window before doing it.
Of course, it pastes at the clicked point...
#7 Posted : Sunday, October 5, 2014 9:18:47 AM(UTC)
Hi Tim
Cannot get a simple circle to work with ctrl c , ctrl v. However the menu copy and paste work in windows.
