BigBoy
#1 Posted : Friday, October 10, 2014 9:27:58 AM(UTC)
BigBoy
Hello,
I am a newbie to ViaCad. I am currently doing a free trial of ViaCad Pro. I have created a few 3d models and when I do model to sheet it only comes out in one view. I have messed around with scale and everything that can be checked, and still only top view. I pulled up a 3d model from the example files and I have the same problem. I must be doing something wrong, or I thought maybe some features are turned off in trial mode.
#2 Posted : Friday, October 10, 2014 10:00:49 AM(UTC)
In the model to sheet dialog box, there is a pull down option for Layouts. The default layout is for one draw view in top. All the other options are four views.
BigBoy
#3 Posted : Friday, October 10, 2014 3:28:17 PM(UTC)
BigBoy
Thanks Tim,
That seemed to do the trick.
