BigBoy
#1 Posted : Monday, October 13, 2014 1:18:24 PM(UTC)
BigBoy
Hello,
I have been working on an old ViaCad tutorial where you use the offset curve. I do not have a problem getting the offset to show at first, but as soon as I pick the cut from solid, the lines showing the offset disappear. Clicking on any tool will make the lines of the offset disappear, what I am doing wrong? By the way the lines of the offset remain red in color-they do not turn black.
#2 Posted : Tuesday, October 14, 2014 10:45:05 AM(UTC)
Originally Posted by: BigBoy Go to Quoted Post
Hello,
Hello,
Are you still having an issue with this? If so can you please post what version of ViaCAD you are using and a screenshot of the offset lines. If you select the one of the lines you offset and look in the inspector what color is listed?
