ukmacnut
#1 Posted : Tuesday, October 21, 2014 9:32:18 AM(UTC)
Hi - My colleague and I have notices multiple lines are overlaid on our work, each time we open our ViaCAD v9 files. Anyone else experiencing this?
Many thanks
Dave
#2 Posted : Tuesday, October 21, 2014 11:41:17 AM(UTC)
Hi Dave
Is it possible you are using the File : Import command? If you File: Import a file, it will merge with the existing drawing. It does not check if you are importing into the same file.
zircon
#3 Posted : Wednesday, January 21, 2015 6:51:57 AM(UTC)
zircon
Japan
I suspect this may be the same issue I described in this post in Punch Lounge.
MacBook Air (13-inch, Mid 2013)
1.7 GHz Intel Core i7
8 GB 1600 MHz DDR3
OSX 10.11.6(Japanese)
SharkCad Pro v10.0.0 (1335)
memphisjed
#4 Posted : Sunday, February 8, 2015 2:36:31 PM(UTC)
memphisjed
Was thanked: 13 time(s) in 11 post(s)
If you can get the original file purged and "overkill" in Acad the double elements tend not to be there on import.
