eolfan
#1 Posted : Friday, October 24, 2014 5:58:34 AM(UTC)
eolfan
Hi
I'm running a Viacad 2D-3D V8.0.0 Build 984 on a HP xw4600 workstation / Windows XP / NVIDIA Quadro FX 370 graphic processor
I've this bugg :
When I open the attached files separately, all is correct but if I open one, then import (viacad) the other file to mix them both , there is a change on the display : all things becomes dark and the Phong shade rendering is disabled.
See the files and image attached.
Michel
ImpBugg.zip (1,616kb) downloaded 10 time(s).
#2 Posted : Friday, October 24, 2014 10:48:26 AM(UTC)
Hi Michel
This repeats for me as well.
It has something to do with merging layers and ambient lights (possibly imported from DXF/DWG). Still checking into..
eolfan
#3 Posted : Saturday, October 25, 2014 9:52:34 AM(UTC)
eolfan
Hi Tim
thanks for your answer
my files were built from viacad without any import from dxf or dwg files.
I had previously the problem sometimes when importing dxf or dwg so I stopped to do that.
It may have something to do with complex shapes when they are merged.
Hope you will find something to fix that.
Michel
