Export to STL>STL Triangles ckd>Update Mesh Parameters Default Program Not Responding !! Win7>Ram 8gb>Ram Video 4gb So now what ??
Hello Are you in Mac or pc? What build number of the program How large is the file before trying to export? Thanks Jason
Win7 = PC 149kb v9.0.0 build 1104
Hello Ok please save file close the program. Reboot of and try again. Thanks Jason
Rebooted.
Same crash.
The object parts were merged using the Add Solid>Export STL>Mesh Parameters update>Crash
Not using Add Solid merging parts>Export STL>Mesh Paramters update>Saved
So whats wrong w/ the merged object vc3 file ?
Edited by user Saturday, November 8, 2014 11:22:44 AM(UTC)
Originally Posted by: whatmeworry Rebooted. Same crash. The object parts were merged using the Add Solid>Export STL>Mesh Parameters update>Crash Not using Add Solid merging parts>Export STL>Mesh Paramters update>Saved So whats wrong w/ the merged object vc3 file ?
Select the merged object and goto the verify in the top menu and select check object
Done verify. OK Same crash.
Ok, Can you post the file ? Regards Jason
The model vc3 was saved in step and opened w/ SW. SW had no probs combining objects, change axis orientation to Z, saving as stl w/ assigned my mesh parameters. There were 3 assemblies w/ combined parts. When none of the assembles were combined(Add Solids) and the model exported to stl, it didnt crash. When 2 of the assembles were combined(Add Solids) and the model exported to stl,it seemed to almost crash, but didnt. When 3 of the assembles were combined(Add Solids) and the model exported to stl, it crashed Ill email it, if you wish.
