#1 Posted : Monday, November 10, 2014 10:31:59 AM(UTC)
Hello,
I can apply some materials (for instance Ceramic.Terracotta) from the render library to my objects as described in the tutorial. Others like Wood Unfinish.Walnut don't work. Sometimes I can apply a certain material only by using the photo render button but as soon as I move the object later on or zoom into it the rendering effect disappears.
I use ViaCad 8 Pro (German edition, v8.0.3), Windows 7 OS, openGL 6.14.10.11672.
Your support is very appreciated. Thx in advance.
Oliver
#2 Posted : Friday, November 14, 2014 1:29:54 PM(UTC)
HI Oliver
Materials, decals, foregrounds, and backgrounds applied with the Render Library display the effects when you select the PhotoRender: User Specified tool. Zooming, and repainting use OpenGL which uses a fast facet based rendering. The PhotoRender tool uses a ray trace approach for better (slower) visualazation that takes into consider materials, reflections, and refractions.
ost
#3 Posted : Monday, November 17, 2014 11:28:51 AM(UTC)
ost
Thx Tim for your support. With your explanation I now better understand what I have to do and the first trials were indeed successful. But in my opinion the manual as well as the video for version 8 are not clear enough - at least for less experienced users like me.
best regards
Oliver
