Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hi Tim,
Is it possible to weld a set of facets in 1 to convert the mesh to solid?
Thank you
Antoine attached the following image(s):
(207kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
>>Is it possible to weld a set of facets in 1 to convert the mesh to solid? Yes, try the Combine tool in PowerPack. Combine is not a boolean operation, but it will take a collection of facets and merge them into one body. If vertices/edges are shared, it will weld and merge. Tim
