Jimbl
#1 Posted : Tuesday, February 3, 2015 10:20:50 AM(UTC)
Jimbl
I am running Shark Lt 1016. When i am drawing in inches all measurements are i inches and less than an inch is in decimals which is fine. When i switch to feet/inches all measurements are in feet and inches the fraction is rounded off to 1/8" even if i am set to 1/16" in the preferences under units.Any ideas or is this a glitch?
Thanks Jim
#2 Posted : Tuesday, February 3, 2015 12:52:15 PM(UTC)
Hi Jim
Drawing pref and dimension tolerance are two separate things. Is the line when clicked on not displaying the fraction at correct tolerance or are you referring to the dimension value. If it is the dimension select the dimension open inspector and change the linear value in the tolerance tab
