Import/Export
multiple lines each time we open
Hi - My colleague and I have notices multiple lines are overlaid on our work, each time we open our ViaCAD v9 files. Anyone else experiencing this? Many thanks Dave
Hi Dave Is it possible you are using the File : Import command? If you File: Import a file, it will merge with the existing drawing. It does not check if you are importing into the same file. Tim
I suspect this may be the same issue I described in
this post in Punch Lounge.
MacBook Air (13-inch, Mid 2013) 1.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 OSX 10.11.6(Japanese) SharkCad Pro v10.0.0 (1335)
Thanks: 36 times Was thanked: 16 time(s) in 14 post(s)
If you can get the original file purged and "overkill" in Acad the double elements tend not to be there on import.
Import/Export
