DanL
#1 Posted : Saturday, February 28, 2015 10:15:56 AM(UTC)
DanL
I don't understand why I can make a simple 3 or four sided multi-line polygon in 3D mode, zoom WAY in, and see no problems, but when I try to cover surface, it reports gaps, with only a request that they must be fixed before that can be done.
Can someone out there help me understand why this pops up and what I can do to fix these darned gaps or prevent them from ever being created in the first place?
DanL
Using ViaCad Pro 7, build 1109, Windows 7
Claus
#2 Posted : Saturday, February 28, 2015 2:19:43 PM(UTC)
Claus
Denmark
I assume the polygon you create is closed. When you make them into a surface you select the lines one by one holding the shift key and only let go of the shift key when they have all been selected.
...or please explain further...
Claus
DanL
#3 Posted : Saturday, February 28, 2015 7:03:28 PM(UTC)
DanL
Thanks, that did the trick. I guess I need to write down all these little quirks, as well as any snaps or other settings that may effect the outcome.
DanL
Claus
Claus
#4 Posted : Sunday, March 1, 2015 9:15:47 AM(UTC)
Claus
Denmark
DanL,
somebody already wrote it all down and called it a manual (sorry couldn't resist). You will find that once you read it things go much easier. You can to almost anything with this program, it's a wonderful tool. Good luck.
DanL
#5 Posted : Sunday, March 1, 2015 3:07:04 PM(UTC)
DanL
Thanks, I started printing that manual out and never finished it. Will do it now.
DanL
DanL,
