Hello I prefer beginning with a bit more layers and the layer "DImension" every time in yellow. What is the best way for a "default template" (protected file)? Regards Roger
Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
Im also interested is there a way to do This?
Martin Krueger ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D _myMill self made CNC milling-machine
Create a file with the layers, views, pen styles that you would like at startup. Save the file and:
Rename your saved file as
startup.dat and place this file in the following location:
Mac
/Applications/ViaCAD Pro 9.app/Contents/Resources/startup.dat
Win
/Program Files/Punch! Software/ViaCAD Pro 9/startup.dat
Each time the app is launched, it will read this file in first.
Edited by user Tuesday, September 22, 2015 11:32:35 AM(UTC)
Thanks Tim i will try that
