Polar Duplicate problem Shark LT
Hi Seems Shark LT is remembering the previous value for the first time I used Shark LT polar Duplicate its stuck with 13 in it, I clear it an enter 8, it still prints 13, then I go back to check and its reset it self back to 13, any help? Thanks Rick
Hi Rick I seem ok here with the current build changing the Duplicates : Number field. What build (see splash screen) and platform are you seeing this on? I'll check with tech support if they have heard of anything. Tim
Hi Tim
Build 1016, using mac book pro
Rick
**Edited to say I have found a way around it, If I open up Polar Duplicate it automatically remembers the old value, when I change that value the OK button becomes un-selectable, however if I am in the numbers field and press Alt/Option and 3 key adding a symbol it resets the number to what I want and the OK button becomes blue again. So there is a work around, but if you know of a fix it would be nice...thanks
Edited by user Tuesday, April 21, 2015 7:25:51 PM(UTC)
