technocnc
#1 Posted : Saturday, May 2, 2015 11:39:44 AM(UTC)
technocnc
Hi all,
I am a new Viacad user, using version Viacad Pro v9. I have a hard time understanding how the associativity works between geometry and the solids created from that geometry. For example, I create a single line rectangle, and insert a fillet in the top right corner. I then draw a circle somewhere inside that geometry.
I use the push-pull function to create the solid. I can change the diameter of the circle and it will be reflected immediately onto the solid, but if I change the fillet radius in the Inspector windows, the associativity is lost and the solid disappear.
How can I change this corner fillet value ? Maybe a basic question, but what happens if I want to change this radius when I am almost done with drawing the part ?
Thank you for your help.
Luc
#2 Posted : Saturday, May 2, 2015 12:51:48 PM(UTC)
Hi Luc
There is associativity between the curves that create solids and surfaces in ViaCAD. However, there is no associativity between the curves (fillet arc and four lines). To create a part that is associative with the fillet, instead of filleting the curves, try to edge fillet the solid.
terry bean on 6/29/2015(UTC)
