ViaCAD 6 printing / Exporting Woes
ViaCAD 6 2D/3D and I suspect that is the problem but at a minimum I would like to know these problems are resolved with later versions Print outs don't look anything like the screen. Print does not show fill or line weights. When I export as jpg it goes all red lines When I try to printdesk as JPG it will not open in Adobe any suggestions or assurance that these are fixed in later versions? Thanks
Hello
You might want to see if your issues are resolved with the latest beta version that is about to be released as a service pack for V9. You can download a fully functional version at:
http://www.punchcadlabs.com/page7/page7.php Note this build also has
PowerPack , which is a separately priced add-on.
if you have a print issue still unresolved, please log a bug report with the example file using:
http://www.punchcadlabs.com/page10/page10.php Tim
Edited by user Saturday, May 30, 2015 1:58:40 PM(UTC)
Thanks, Server must be down I get a 404 with the link
Third time is a charm it loaded but I guess it is 64bit only application
