Gzuk
#1 Posted : Saturday, May 30, 2015 12:58:53 PM(UTC)
Gzuk
ViaCAD 6 2D/3D and I suspect that is the problem but at a minimum I would like to know these problems are resolved with later versions
Print outs don't look anything like the screen. Print does not show fill or line weights.
When I export as jpg it goes all red lines
When I try to printdesk as JPG it will not open in Adobe
any suggestions or assurance that these are fixed in later versions?
#2 Posted : Saturday, May 30, 2015 1:12:15 PM(UTC)
Hello
You might want to see if your issues are resolved with the latest beta version that is about to be released as a service pack for V9. You can download a fully functional version at:
http://www.punchcadlabs.com/page7/page7.php
Note this build also has PowerPack, which is a separately priced add-on.
if you have a print issue still unresolved, please log a bug report with the example file using:
http://www.punchcadlabs.com/page10/page10.php
Edited by user Saturday, May 30, 2015 1:58:40 PM(UTC)  | Reason: Not specified
Gzuk
#3 Posted : Saturday, May 30, 2015 4:17:32 PM(UTC)
Gzuk
Thanks, Server must be down I get a 404 with the link
Gzuk
#4 Posted : Saturday, May 30, 2015 4:33:01 PM(UTC)
Gzuk
Third time is a charm it loaded but I guess it is 64bit only application
