fasteners - well real 3D support for symbols
I'm new to Viacad Pro v9. But I have experience with Vectorworks as well as SolidWorks. Unfortunateley now that I have retired I can no longer afford either of them. One of the reasons I bought Viacad was its symbol libraries which promised thousands of 3D symbols. Now I see they are essentially useless for what I want which is a threaded hole in a part and the correspnding fastener. I have crawled through the forums which tell me to go find 3D models at Macmaster Carr among others. Well, I have tried that but I am not finding any such libraries for download. A little help please. cfly
Thanks: 15 times Was thanked: 31 time(s) in 27 post(s)
i usually go to Grabcad for technical models, you might try your luck there. Claus
1 user thanked Claus for this useful post.
Originally Posted by: cfly I have crawled through the forums which tell me to go find 3D models at Macmaster Carr among others. Well, I have tried that but I am not finding any such libraries for download. A little help please. cfly
Hello cfly
McMaster carr has 3d models of fasteners but you have to download each one you need there are no libraries to download a bunch at once.
Yes, I saw that. I suppose I could try that and just download each one that I use. Thank you cfly
you may want check the following too:
http://www.traceparts.com/ http://www.3dcontentcentral.com/ http://cad.thomasnet.com/ do prefer the SAT format (if available) which is native for ViaCAD (ACIS kernel), otherwise STEP.
I tried all three of those. While the 3D drawings are there they do not show the threads. That's true of almost everywhere I looked. I have flound a OPENScad script called ISOThread.scad. OPENScad is programmable and Trevor Moseley has writted an scad scipt with produceds finished metric bolts and internal threads. I have the script source. I don't think it will be very difficultt to create one for Imperial threads. The scad script generates meshes which I was able to convert to a solid by stitching. And the resulting solid correctly forms the external or internal thread when added or subtracted to the object needing threaded holes. So I saved an internal thread m8-10 as a symbol. When I use concept explorer to add the symbol, the symbol cannot be added or subtracted from the parent object. Any suggestions. If I get this to work I will create a symbol library and donate it. cfly
did you ungroup the symbol after dragging into the drawing?
Is the openscad part a polygon mesh or a mathematically precise solid that you are trying to subtract from another part?
Originally Posted by: cfly I'm new to Viacad Pro v9. But I have experience with Vectorworks as well as SolidWorks. Unfortunateley now that I have retired I can no longer afford either of them. One of the reasons I bought Viacad was its symbol libraries which promised thousands of 3D symbols. Now I see they are essentially useless for what I want which is a threaded hole in a part and the correspnding fastener. I have crawled through the forums which tell me to go find 3D models at Macmaster Carr among others. Well, I have tried that but I am not finding any such libraries for download. A little help please.
You could
try this post Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
