Problem Powerpack simplify Profile
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
I use simplify profile from powerpack to get rid of hundreds of tiny lines from an airfoil. But this seems to cause a lot of trouble. Here is one. When i do a simplify profile on the airfoil it moves the foil away from its origin point. see pics. Is this a known problem or do i something wrong?
Edited by user Wednesday, October 21, 2015 1:41:40 PM(UTC)
martinwh99 attached the following image(s):
(58kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Martin Krueger ViaCAD ProV9, Cut2D, Cut3D _myMill self made CNC milling-machine
Hi Martin Can you send me the file with just the profile you want to simplify? Tim
Hi Tim
Here is the file.
Other problem i have is that when doing a 2 rail sweep with a simplifyed profile the nurb does not behave like i'm used. But i have to figure that out when this problem here is solved:-)
Höhenruder_1.vcp
(1,693kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Here a screen cast what i'm doing
https://youtu.be/5_0H79hfp2U Martin Krueger ViaCAD ProV9, Cut2D, Cut3D _myMill self made CNC milling-machine
>>Here is the file. Received, I'm tracking down some accumulated tolerances issues with the simplify command. Tim
I've made some updates with the Simplify tool and tolerances. Plus I now report the maximum deviation after a simplify operation. In your example it was not following the tolerances. Build 1174 will have the corrections. I've also made some updates when simplifying lines to arcs and splines.
Edited by user Friday, October 23, 2015 12:55:30 PM(UTC)
(272kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
I used your rudder example file to do some more testing of PowerPack. One possible approach to creating a wing from your data is instead of converting to a polyline, convert to a spline. Below is a video showing that possible workflow.
https://youtu.be/-oWNAX4d-AE Tim
Tim, thanks a lot. It did work like you have shown in the screen cast. I did the 2 rail sweep in two parts (the strait one and the curved) and then joined the surface. Also i do not have the options when doing simplify operation, is this new or a different package?. Where can i get the build from, or is it not yet available.
