martinwh99
#1 Posted : Wednesday, October 21, 2015 1:38:22 PM(UTC)
martinwh99
Switzerland
I use simplify profile from powerpack to get rid of hundreds of tiny lines from an airfoil. But this seems to cause a lot of trouble. Here is one. When i do a simplify profile on the airfoil it moves the foil away from its origin point. see pics. Is this a known problem or do i something wrong?
Edited by user Wednesday, October 21, 2015 1:41:40 PM(UTC)  | Reason: Not specified
martinwh99 attached the following image(s):
before Simplify overview.jpg (99kb) downloaded 11 time(s).
before Simplify detail.jpg (52kb) downloaded 12 time(s).
after Simplify detail.jpg (57kb) downloaded 10 time(s).
after move back to origin.jpg (58kb) downloaded 8 time(s).
Martin Krueger
ViaCAD ProV9, Cut2D, Cut3D
#2 Posted : Wednesday, October 21, 2015 1:42:37 PM(UTC)
Hi Martin
Can you send me the file with just the profile you want to simplify?
martinwh99
#3 Posted : Wednesday, October 21, 2015 1:53:16 PM(UTC)
martinwh99
Switzerland
Hi Tim
Here is the file.
Other problem i have is that when doing a 2 rail sweep with a simplifyed profile the nurb does not behave like i'm used. But i have to figure that out when this problem here is solved:-)
Höhenruder_1.vcp (1,693kb) downloaded 7 time(s).
Martin Krueger
martinwh99
#4 Posted : Wednesday, October 21, 2015 2:20:11 PM(UTC)
martinwh99
Switzerland
Here a screen cast what i'm doing
https://youtu.be/5_0H79hfp2U
Martin Krueger
#5 Posted : Thursday, October 22, 2015 9:55:20 AM(UTC)
>>Here is the file.
Received, I'm tracking down some accumulated tolerances issues with the simplify command.
#6 Posted : Friday, October 23, 2015 12:51:22 PM(UTC)
I've made some updates with the Simplify tool and tolerances. Plus I now report the maximum deviation after a simplify operation. In your example it was not following the tolerances. Build 1174 will have the corrections. I've also made some updates when simplifying lines to arcs and splines.
Edited by user Friday, October 23, 2015 12:55:30 PM(UTC)  | Reason: Not specified
#7 Posted : Friday, October 23, 2015 2:26:59 PM(UTC)
I used your rudder example file to do some more testing of PowerPack. One possible approach to creating a wing from your data is instead of converting to a polyline, convert to a spline. Below is a video showing that possible workflow.
https://youtu.be/-oWNAX4d-AE
martinwh99
#8 Posted : Tuesday, October 27, 2015 2:05:53 AM(UTC)
martinwh99
Switzerland
Tim, thanks a lot. It did work like you have shown in the screen cast. I did the 2 rail sweep in two parts (the strait one and the curved) and then joined the surface. Also i do not have the options when doing simplify operation, is this new or a different package?. Where can i get the build from, or is it not yet available.
Martin Krueger
